Quad-core q6600 64bit
Old   January 9, 2008, 08:46
Default Quad-core q6600 64bit
giogio
Hi I have a quad-core q6600 64bit (Intel 2.4 GHz), how can I work with all processors at 100% for running simulation in Fluent? Is there some difference for a 64 bit?
Thanks
Old   January 9, 2008, 09:53
Default Re: Quad-core q6600 64bit
cfd_newbie
If you have a parallel license for Fluent you could try for example the command:
fluent 2ddp -t4
in this way Fluent will use your four processors. What operating system you use ?
KW
You need the 64-bit version of fluent and you will also have to run in parallel. The user guide talks about running parallel--you would use the -t4 option when you start fluent from command line although you can also do it through the GUI. Incidentally, this also means you need 4 fluent licenses (which is stupid, but that's the way it is).
Old   January 9, 2008, 15:03
Default Re: i hv pentium D
anup
i hv pentium D ..it has two cores .... what should be the command?
Old   January 9, 2008, 15:07
KW
fluent version -t2 This will start two fluent nodes on your machine, one on each core. It also requires two licenses.
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
4 core & 8 core: same 64bit XP, Xeon, x5570, 2.93GHZ leeruoyun CFX 4 August 19, 2009 00:47
Parallel computing quad core Prad Main CFD Forum 13 February 9, 2009 14:28
Questions about CPU's: quad core, dual core, etc. Tim FLUENT 0 February 26, 2007 14:02
