Fogging / Mixing Problem
Old   October 26, 2009, 19:30
Default Fogging / Mixing Problem
ADI
A. N.
ADI is on a distinguished road
Send a message via MSN to ADI
Hello All,
I am new to CFD so I don't have much experience in the field and I need help.
For my research I am trying to model a vapor mixing with ambient air. The vapor is diesel based oil (used for thick fog generation) in gaseous phase which is coming out of 5x 1/16 inch diameter holes at 1050 deg. Fahrenheit and 1000 Pa gauge pressure. I need FLUENT to show me how it is mixing with the air (air entrainment), where the temperature of the vapor is 870 deg F and the fogoil to air ratio in terms of volume fraction and mass fraction.
After doing some research, I found out that I can get a Volume fraction ratio if i use multi-phase model but I have to use single phase Multi-component model to obtain mass fraction ratio.
So I am confused as to what model I should use and how to set the boundary conditions.
If you have experience in this sort of simulation or modelling please help me out as I am under a little time crunch as well.
ADI is offline   Reply With Quote
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
mixing plan problem ravindra bankar FLUENT 2 May 12, 2006 03:41
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
HELP!: swimming pool flow problem Tee FLUENT 1 September 8, 2005 08:29
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
