Periodic BC
Old   December 18, 2007, 12:26
Default Periodic BC
Valerio
I'm trying the simulation of a swirling separator...it has a periodic flow field, i have some problem on setting this kind of BC...can someone post me any document/link/tutorial on this BC?
thank you very much
Valerio
Old   December 19, 2007, 00:39
Default Re: Periodic BC
Vijay
Dear Friend, i have one help file please can u send me ur mail id........
Regards, Vijay
Old   December 19, 2007, 05:21
jaysree
hi, Vijay, can u please send me the help file for periodic boundary condition. I am also struggling with similar problem. my mail id is jaysreeiisc@gmail.com
Old   December 19, 2007, 06:37
Vijay
Dear Friend,
To apply a "periodic" boundary condition for use with a FLUENT solver, you must first create a mesh hard link between the pair of edges (2-D) or faces (3-D) to which the boundary condition is to apply. In addition, you must assign a PERIODIC boundary type to both edges (or faces) in the pair, and both edges (or faces) must constitute members of a single entity set.
With Regards, Vijay
Old   December 20, 2007, 02:42
Raj
Adding on to what vijay said, all these u have to to do in TUI mode of fluent, there is tutorial in fluent that uses this feature.
Regards Raj
Old   December 20, 2007, 06:36
jaysree
It is it available with help file of fluent6.0.Otherwise can you please send it to my mail id. Thankyou verymuch with regards,] Jaysree
Old   December 25, 2007, 05:56
Vijay
Hi jaysree, I have sent u an help file to ur gmail account regarding ur periodic BC have u received it.........
With regards, Vijay
Old   January 7, 2008, 07:11
Francesca
Hi, i have a problem with command Link Face Meshes of Gambit. Is there a tutorial that explain how to use this command? Tanks Francesca
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
rotational periodic boundary conditions in ICEM user0314 ANSYS Meshing & Geometry 1 June 21, 2011 01:57
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 15:36
