Airfoil Average Nusselt Number calculation
Old   March 2, 2011, 22:46
Default Airfoil Average Nusselt Number calculation
y2k_o__o is on a distinguished road
Hi everyone my current version of ANSYS Fluent is 12.1
The type of flow I am using is a Spalart Allarmaras Model
Please correct me if I am wrong
Now, I wantwant to calculate an average nusselt number from the Solution
so do I just simply click "monitor" -> " Surface Monitor"
Report Type: Integral
Field Variable: Wall Fluxes, Surface Nusselt Number??
and also how do I calculate the Reynolds number of the flow as well ?
Thanks =)
y2k_o__o is offline   Reply With Quote
Old   March 3, 2011, 00:25
I have the Nusselt Number Distribution around the airfoil
does the Nu Distribution look like that ?
and how do I average them ? just add them all and divide by the number of point, n ???
ps: this airfoil is a unit length airfoil
Thanks
Old   March 3, 2011, 02:41
Amir's Avatar
Amir
Amir is on a distinguished road
before computing Nu No., be sure that your reference values are correct.(report->reference values)
I think for evaluating average Nu No., you can compute total heat transfer from airfoil and then obtain an equivalent h(heat transfer coefficient) and then compute Nu.(just a suggestion)
Amir is offline   Reply With Quote
Old   March 3, 2011, 03:47
Originally Posted by Amir View Post
Yes I've checked the reference value are the correct for air properties
as far as obtaining equivalent h from total heat transfer...
what delta temperature should I use ?? ( Temperature varies along the chord length too)
Thanks,
Old   March 3, 2011, 04:21
Amir's Avatar
Amir
Thanks,
I think it's a good idea to use dT=(Tave-Tinf). you can obtain Tave from report->surface integral->average facet. isn't it?
Old   March 3, 2011, 05:45
so what you're saying is:
h_avg = overall_heat_transfer_rate / ( T_avg - T_fluid )
Nu_avg = h_avg * chord_length / k_fluid
Old   March 3, 2011, 07:37
Amir's Avatar
Amir
yes, it's right if T_fluid & k_fluid remain constant during solution.
Nusselt number calculation in Fluent Sharadkumar Yeri FLUENT 52 May 29, 2019 06:29
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
Nusselt Number jlx Main CFD Forum 2 January 14, 2011 13:30
Warning 097- AB Siemens 6 November 15, 2004 04:41
