floating point error
Old   December 15, 2007, 14:52
Default floating point error
safa
I'm running a 2ddp, pbns, eulerian, spe, laminar, unsteady case. If I put a small number of iterations per time step, every thing is ok. However, if I increase the number
of iterations (20 for example) I got a message error just after approximately 18iterations :
Error: floating point error: overflow Error Object: ()
Why did this happen for large iteration's number and how can I remedy?
Thanks
Old   January 9, 2008, 05:46
Default Re: floating point error
prakash
hi,
i oftenly get this msg " error: divide by zero" after finished convergence results when i see the results. wat is the problem? could u tell me where i did mistake?
Old   January 9, 2008, 15:13
safa
Sincerely, I have no idea!! (( I got this error previously. I think it can be related to some strange values encountred while iterating or some errors concerning the values you entered while setting the case.
Well, in any case, try to be precise as possible as you can when setting your case! that's all i can tell you! sorry! sometimes errors occur because of very insignificant lack of attention!! good luck
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
