Urgent! 2*Roughness Height >grid height
I am modeling open channel flow(2D). The wall roughness height Ks=0.07m and the flow depth H=0.1m.
Frist question is: According to Fluent User Guide, the distance from the wall to the centroid of the wall-adjacent cell should be greater than Ks, implying my first cell height should be 2*Ks=0.14m,which is larger than the flow depth H=0.1m!It's impossible to mesh it! Second: For i use the K-e turbulence model.If i choose the Enhanced Wall Treatment,which require the Y+ <5.The first cell height will be almost 0.0001m.It's inconsistent with the first question,too. What should I base my cell height on? Please help! Thanks in advance!rodi |
Re: Urgent! 2*Roughness Height >grid height
roughness height larger than 1st cell height is meaningless. Use standard wall functions and Y+=30-100 range. A wall roughness of 0.7m is not valid for the empirical data (nikuradse) where k/Dh is massive. You need to model explicitly.
Thanks for your reply~!
The roughness height(Ks) is computed from the constant(n) in Manning's formula. In my case, n=0.025 and there is a empirical formula : 1/n=17.72*lg(11.89/Ks), then Ks=0.066m As the User's Guide says,make sure that the distance from the wall to the centroid of the wall-adjacent cell is greater than Ks. 1st cell height should >0.132m (2Ks), at the same time, Y+ will out the range of (30,100).It looks like incompatible! Could you help me? Best regards!rodi |
