Gambit: too long meshing time!
Old   January 29, 2008, 16:18
Default Gambit: too long meshing time!
delsolman
Hi I have problem with too long meshing time... I have this geometry: http://s5.directupload.net/images/080129/d6huhnoo.jpg
I have many modifications where I change the distance between car1 and car2. One case mashing Gambit fast but in another case has Gambit problems...diference is that in first step Gambit very fast (in few seconds) compute elements to 500 000...and then create background and start meshing but very slowly and mostly with errors...
Please do you know where is problem?
Thanks for help. Lukas
Old   January 29, 2008, 19:06
Default Re: Gambit: too long meshing time!
AAA
Hi
In Gambit, use a size function (Tools--> sizing function-->Create size function) and choose the two cars to be the "source" and the whole domain to be the "attachment". Use a proper "start size" based on the size of the car, a "growth factor" of 1.2 (20%) and a proper "end size". Then mesh the domain by the normal way.
You can also create many cars in Gambit with interiors as BCs, each having a separate zone (Zone-->continuum). In Fluent, Deactivate the car you want to analyze the flow around (Grid-->Zone-->Deactivate). This will change the interior boundary to a wall.
Good luck
AAA
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
Gambit meshing error jx FLUENT 11 May 26, 2009 10:35
