Methane combustion kinetics
Old   January 17, 2008, 06:08
Default Methane combustion kinetics
DEV
I need methane combustion kinetics of reaction
1) CH4 + 2O2 ==> CO2 + 2H20
2) CO+ 0.5O2 ==> CO2
I need these kinetic parameters of both reactions in following units : k (m3/kmols) and E (J/Kmol)as I am finding it difficult to get them in this units.
Kindly also provide references from where this values are taken.
Thanks in Advance
DEV
Old   February 5, 2008, 03:00
Default Re: Methane combustion kinetics
Claud
Hi DEV, just check out the following mechanism: Gri30-Mechanism at http://www.me.berkeley.edu/gri_mech/.../grimech30.dat. There you can find all your kinetic parameters or you could even use the whole mechanism for your methane combustion problem since you can import the chemkin format file easily. Hope this helps. Claud
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
Temperature drops in Methane combustion CPRL Siemens 0 July 24, 2007 12:56
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 09:16
Methane combustion in gas burner Stefano CFX 1 June 7, 2005 02:12
Methane Combustion Lars FLUENT 4 March 5, 2003 08:24
