Fatal error in GAMBIT
Hi Sometimes in Gambit when I run a heavey command, like meshing many volumes simultaneously it gives Fatal Error. Whats the reason behind this? Is it memory problem?
Regards |
Re: Fatal error in GAMBIT
It is probably a memory issue. You can monitor the memory acquired by each program in the "task manager" processes. Press ctrl-alt-delete. You probably already know this.
This will answer your question ultimately. Best regards Kasper Skriver |
| All times are GMT -4. The time now is 02:37. |
