Home > Forums > FLUENT
Set velocity in BC
Old   January 21, 2008, 11:19
Default Set velocity in BC
Xavi
Hi! I have a 2D model and I would like to fix the components of velocity in one of the edges as follows: Vy=0 Vx= not fixed (is computed by FLUENT).
Does anyone know what kind of BC should I use? Many thanks Xavi
Old   January 21, 2008, 12:02
Default Re: Set velocity in BC
Leverkin
You can write a simple UDF tha access the edge you want and set the Vy = 0. There is an access macro command that allows you to do that: C_U(c,t) and C_V(c,t). You can try that.
Old   January 22, 2008, 07:50
Xavi
Thanks! I am trying to find out more info about UDFs, What does the c mean? is it a constant?. Do you know exactly what should the text of the UDF be? thanks
Old   January 22, 2008, 08:40
Leverkin
"c" stands for cell, "f" for face and "t" for thread.
It will look like that
include "udf.h"
DEFINE_PROFILE(velocity,t,i) {
real r; cell_t c;
begin_c_loop(c,t)
C_V(c,t) = 0 }
end_c_loop(c,t)
try this. It will probably works.
Old   January 24, 2008, 07:52
Xavi
Mnay thanks! I found out an easier way to do that: impose the boundary condition: "symmetry" and then the Vy=0 and Vx is computed. Cheers, xavi
Thread Tools
Trackbacks are On
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 06:15
can i set the velocity and pressure at the inlet at the same time by UDF minyang.cau FLUENT 0 July 14, 2009 23:14
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
How to set transient ang velocity? edi ghirardi FLUENT 0 April 12, 2005 09:34
