grid
Old   January 25, 2008, 05:39
Default grid
Amit
Hello frns,
I want your help, i want to mesh a geomotery with first cell distance of the order of sub microne (for hypersonic flow computations). I know the options to do so. But in gambit it shows a warning that i am exceeing geomoteric tolerence limit and ** it will create negative volume while going to sub microne levels. On other hand i can write a simple program to do so. please help me, how to do this in gambit.
Thanks in advance
Old   January 25, 2008, 05:48
Default Re: grid
Kasper
Maybe you should consider to make the cells a factor 1000 bigger. Then scale the mesh later in Fluent. You can just do a simple test to see if it works.
Br Kasper Skriver
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
