cluster - dynamic adaption
Old   January 29, 2008, 03:13
Default cluster - dynamic adaption
bohis
Hi everybody,
I have a simple 3d VOF job running on the unix cluster (4nodes)and Linux is reporting job Unknw. Why is it not working? Do you think there is some problem with dyn. adaption (because the mesh refinement and coarsening go through those particular nodes) I do not know Jack
Old   January 29, 2008, 10:38
Default Re: cluster - dynamic adaption
Phil
Cut and paste exact error.
Give more details of cluster etc.
Old   January 29, 2008, 10:52
bohis
ohh, thanks for reply. Unfortunately, the process hasn't crashed, so there was no error message in output file. I had to kill the job, because Linux was reporting Status: Unknw and no data were stored during 24 hours via autosave. That is why I think nothing went wrong, but what? You mean there should be no problem with dynamic gradient adaption within parallel processing, do you?
Thank you very much, Jack
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mesh Adaption in CFX. Kushagra Mittal CFX 1 August 31, 2011 08:17
dynamic mesh and grid adaption Dennis FLUENT 1 June 2, 2007 23:59
dynamic mesh adaption alessio FLUENT 0 May 13, 2006 14:53
Dynamic Gradient Adaption: Mulitple Field Variable Steve FLUENT 0 July 12, 2005 17:36
