mass flow rate of "interior"
Old   February 1, 2008, 11:25
Default mass flow rate of "interior"
Dong Fu
Hi all
When you use FLUENT "Report-->Fluxes-->Mass Flow Rate"
What dose mass flow rate of "interior" mean?
Because I found there is mass flow rate in the interior which will not conut when you check the mass balance.
Thanks in advance
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 05:55
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
