February 3, 2008, 13:31 |
Natural convection over a vertical wall
Dear All
Im new to computational fluid dynamics.I am trying to study natural convection over a vertical wall with sources of heat along the wall. the wall is 45 m high with a heat source every 10 m and 5 m wide. I am using gambit to generate the geometry .My question is how do i specify the boundary conditions? do i draw an outer boundary around the wall like a huge box .and if the wall has one side with the heat source how do i specify the other parts of the wall as adiabatic. I hope it clear enough .Any help would be much appreciated THanx in advance |
February 3, 2008, 14:04 |
Re: Natural convection over a vertical wall
hi
you can draw a box which walls are 45m. and select a vertical wall in boundary conditions menu and set wall. other walls must be presure inlet. open mesh file in fluent and set temperature for vertical wall than, set temperaturte (ambient temperature) for presure inlets in boundary conditions menu. You have to use bossinesq approximation in materials menu (for air, beta=0.00343 1/K) and selecet PRESTO and second order at solution control. Dont forget to use ununiform mesh. finest mesh must be at near the vertical hot wall. |
February 3, 2008, 15:10 |
thanx Phy i will try that but i need to ask i mesh the area around the wall not the wall itself ....right or not?
February 3, 2008, 19:22 |
I cant understand. but please think in 2D. only draw a box and mesh it. than set boundary conditions.
check this site http://courses.cit.cornell.edu/fluent/plate/index.htm this is forced convection and horizontal plate, so thera are a velocity inlet. but in your model, this is presure inlet and plate is vertical. |
February 3, 2008, 19:57 |
You are interested in the FLUID so yes you mesh the air volume around the wall. Obviously the wall itself is solid so you don't mesh that. When you set up the problem in fluent, you will specify the temperature of the wall and give it a thickness. Hope this helps, Carlos. |
February 3, 2008, 20:05 |
yes, it is very obvious. thanks
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Natural convection flow over hot vertical plate | M.sridhar | FLUENT | 8 | June 6, 2011 08:46 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
natural convection in a square enclosure with a partial dividing wall | sandeepmishra | FLUENT | 3 | May 6, 2000 04:25 |
