February 5, 2008, 19:09 |
UDF - volumetric heat generation
Please, IŽd like to known how can I make a UDF to have a volumetric heat generation(source files) time dependent or temperature dependent(in both cases).
If it was possible, IŽd like the complete procedure because I have tried for many times, but I failed to do it. |
April 5, 2019, 02:15 |
Jeswanth Ravula
Hi Thiago, Did u find any solution for the below mentioned query.
heat flow UDF on coupled surface (wall-shadow wall) | Friedmann | Fluent UDF and Scheme Programming | 0 | August 5, 2010 10:25 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
how to impose experimental dat as boundary conditi | Rogerio Fernandes Brito | FLUENT | 14 | November 25, 2008 05:47 |
Heat flux UDF problem | Paul | FLUENT | 1 | September 11, 2003 06:13 |
Heating of a solid cylinder with internal heat generation | Sriram Popuri | Main CFD Forum | 6 | July 13, 1999 18:09 |
