Home > Forums > FLUENT
time step
Old   February 5, 2008, 21:19
Default time step
I am confused about the terminology time step used in fluent. Let's say the time step is 0.1. What does it mean? i am also not certain about the max iteration per time step.
Old   February 7, 2008, 12:37
Default Re: time step
Let's say your time step is 0.1s. Next you can choose the number of time step, for instance 10. It means that you will have your flow every 0.1s. But at the end you will have the result of your flow after 1s. I don't know if it is clear what i am saying. Fluent calculates your flow every 0.1s. Next for max iteration per time step, is the number of iteration that you ask to fluent to do to have converged. I advice you to put a big number as 10000, like that your are sure that you calculation is converged. If your calculation converged before the 10000iterations, fluent goes to the other time step
Old   February 7, 2008, 13:11
thanks clementine
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
HELP! time step too small? meangreen Main CFD Forum 5 August 27, 2009 12:32
