February 6, 2008, 00:07 |
Question about meshing
Hi, I hope someone help me. I have a question. There is a grid that meshed by hexahedral and tetrahedral elements. So in one computational domain, hexahedral and tetrahedral elements are coexisting. If I use such a grid, can I get a reasonable solution?
Thanks, akr |
February 8, 2008, 05:43 |
Re: Question about meshing
Yes you can mix different types of cells in a domain and get good results. It works fine for me! The key is to use as many hex cells as possible to reduce numerical diffusion. You can then use Tet cells for complex geometry.
A good method is to create your domain then split with connected faces and mesh the individual sub-volumes as appropriate. Good luck, Carlos. |
[ICEM] 2d Aerofoil meshing in ansys ICEM | syler3321 | ANSYS Meshing & Geometry | 2 | February 3, 2012 02:59 |
is free meshing or mapped meshing is best for flow problems | shanu | Main CFD Forum | 0 | February 18, 2010 12:58 |
[Other] is free meshing or mapped meshing is best for flow problems | shanu | OpenFOAM Meshing & Mesh Conversion | 0 | February 18, 2010 12:56 |
GAMBIT meshing scheme | rayy | FLUENT | 4 | February 12, 2007 10:26 |
gambit meshing scheme question | Juliana P | FLUENT | 1 | October 28, 2005 10:15 |
