February 6, 2008, 07:51 |
Boussinesq model gives constant density
I'm using the Boussinesq model for density for a natural convection problem with water. I've set the operating temperature and thermal expansion coefficient for water. The temperature difference is a maximum of 25K but still the density contours are constant throughout the entire domain. However I do get a velocity field and the only driving force I have is buoyancy so there must be some density difference. Why can't I see it in reports or contours? Regards Ola |
February 13, 2008, 03:30 |
Re: Boussinesq model gives constant density
The Boussinesq-Approximation is applyed just to the buoyancy-expression in the navier-stokes-equations and not to the general density, which is treated as constant.
I experienced the same problem with a natural convection problem. The density was constant all over the area. But I got the right solution for the velocity-field. Therefore I suppose there is an other problem with your simulation. |
February 21, 2008, 07:51 |
If you did not use a boundary layer in the vicinity of a wall, you may not observe those density gradients. Try meshing with a boundary layer in gambit
June 11, 2018, 16:54 |
#4 | |
Rep Power: 7 |
June 12, 2018, 09:28 |
Andrea
The entire point of the Boussinesq approximation is to avoid the complications arising from considering the density as a temperature-dependent property.
In the approximation the density of the fluid is taken as a constant and the buoyancy effects are accounted for in the N-S with the extra term -rho_ref*g*beta*(T-Tref) where rho_ref is the (constant) density of the fluid at the reference temperature, g is the gravitational acceleration, beta is the thermal expansion coefficient and (T-T_ref) is the difference between the local and the reference temperature. Basically it is assumed that g*(rho(T)-rho(T_ref)) ~ g*beta*rho_ref*(T-T_ref), which allows to drop the dependency of rho on the temperature. This is only reasonable if beta*(T-T_ref) << 1. If this is not the case, than you should drop the Boussinesq approximation and go with a varying density instead. Therefore I would be surprised to see any density gradient in this case, no matter how refined is your mesh. Andrea |
boussinesq approximation, density contour |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 03:34 |
how to set Boussinesq model for homogeneous binary mixture | richard2000 | CFX | 3 | September 14, 2010 03:04 |
Model foaming process: change the volume / density | pmp77 | CFX | 0 | November 18, 2008 09:53 |
Density model | ritmat | FLUENT | 0 | May 16, 2007 09:29 |
about boussinesq model | appleyy | FLUENT | 4 | April 3, 2001 20:42 |
