Home > Forums > FLUENT
ERROR: can't convert face into submappable region
Old   February 6, 2008, 09:36
Default ERROR: can't convert face into submappable region
George
Hi, this may seem like a relatively simple question but I really need some help with this.
I am modelling in 2D an airfoil inside a circle. The airfoil is constructed from edges joining 400 vertices. I have set the number of nodes on each airfoil edge as 1. I then set the number of nodes on the circle as 400. But when I try to mesh the face GAMBIT says 'ERROR: face could not be converted to a submappable region'.
I have tried looking in the user guide but can't really find anything of much help.
I am a new user of GAMBIT and not familiar with all its functions so bare with me
Old   February 7, 2008, 15:25
Default Re: ERROR: can't convert face into submappable reg
anup
the one to one relation cant be found by mapping ..... i would sugest u to go through the gambit help files....
Old   February 8, 2008, 04:47
Carlos
Basically, what Anup means is that in order to use a mapping scheme you need the same number of nodes on the cicrle as the airfoil. You can either mesh each of these again using node count instead of defining the distance between node points as is the default and then remesh.
Or you could choose a different scheme such as a tetrahdral unstructured mesh. More advanced methods allow you to sub-divide your domain first by using the split command to split faces with edges. This then allows you to mesh your domain in individual sub-domains. It gives you more control over how much you vary the nodal density and starting inside out is good practice.
If you do this remember not to stretch mesh elements too aggressively. Try checking the quality after you mesh and aim to keep the equiangle skew below 0.85 if possible.
Good luck,
Carlos.
Old   February 10, 2008, 15:48
anup
yeah and also use the check button in gambit to check how many cells are beyond the max limit ( the normal practise is to keep the ratio less than 1:10 in case of sides of a quad mesh or the skewness to 0.85)
Thread Tools
Trackbacks are On
Import netgen mesh to OpenFOAM hsieh Open Source Meshers: Gmsh, Netgen, CGNS, ... 32 September 13, 2011 05:50
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
