HELP PLS.........
Hi friends can any body please help me to write an UDF for Velocity inlet with respect to time for following readings please........ Or please send me some help file related to this friends...... Thanks in advance......
Time(s) - 5 3 7 Velocity(m/s) - 5 10 8 Thanks for ur reply friend....... Regards, Vijay |
Re: HELP PLS.........
are you trying to specify your vel profile as a step function or what? If so, you need to use a UDF with an array that would allow you to specify for a given number of time steps, the velocity... I assume you are running an unsteady simulation? Good luck. James |
