Home > Forums > FLUENT
Gambit
Old   February 16, 2008, 16:57
Default Gambit
edwin
hi,
i have a problem finding out how many nodes/element that was generated by the mesh. It comes out after you mesh it but how do we check after meshing?
Old   February 16, 2008, 18:03
Default Re: Gambit
Manfred
Check elements in the Mesh menu, it shows you th number of nodes for each edge, surface or volume (depending on the chosen menu). Then you have to make the sum.
I don't know if there is another method, hope it will help.
Old   March 1, 2008, 10:04
Default Re: Gambit
Vinod Dhiman
You can directly get the number of cells or nodes or faces in Gambit. In mesh menus, there is always second last button which when showing i can be used to get that information. If you want to know number of elements in volume mesh, just go to volume mesh menu, click on the button with i, select the volume(s) and click apply. It will give you whole of the information.
Thread Tools
Trackbacks are On
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
