Home > Forums > FLUENT
FLuent not wotking in x86_64
Old   February 19, 2008, 04:42
Default FLuent not wotking in x86_64
praveen M
Hi i am using Cenos 5.0 x86_64 installed on intel Core 2 Duo. I have installed fluent6.3.26, when i treied to run fluent i am getting the following error message. Error: directory /home/fluent/Fluent.Inc/fluent6.3.26/fluent[0-9]* does not contain a valid arch. Set the environment variable FLUENT_ARCH and try again.
Please some can help?
Old   February 19, 2008, 05:59
Default Re: FLuent not wotking in x86_64
rob
Try downloading a later version of Fluent
Old   February 19, 2008, 06:26
pulgarcito
Please try this:
open a shell (I think you are using bash) and write
export FLUENT_ARCH=lnamd64
enter
then launch fluent.
If it works change your .bashrc file to fix it.
good luck!
Old   February 19, 2008, 08:55
Phil
6.3.26 works fine on Centos 4.x 64 bit.
Thread Tools
Trackbacks are On
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
