February 20, 2008, 12:44 |
meshing triangular channel
Dear friends
I have a problem with meshing the triangular channel since I try all types of mesh but the mesh did not generated to the triangle channel. Please who can to help me to meshing my channel with thanks |
February 20, 2008, 14:22 |
Re: meshing triangular channel
Use the Triprimitive option. To apply this mesh topology you must change all nodes in face to the End type
February 20, 2008, 15:17 |
Thank you
But how to change the nods to end type and this type of mesh Triprimetive to the faces or volumes |
February 22, 2008, 11:31 |
In the face mesh icons there is icon (in top and 4th from left). then select the face and select the node. then click on End and then press apply. It should work.
After changing to all nodes in triangle to End , the default scheme for meshing will be the triprimitive. |
Thin Channel Meshing in DM | chires | ANSYS Meshing & Geometry | 1 | March 29, 2011 18:51 |
How did I give a triangular curve (open channel problem) ? | Andy Chen | FLUENT | 0 | June 22, 2009 00:13 |
help with meshing trapezoidal channel | rosol | FLUENT | 0 | September 14, 2007 03:26 |
Please help me to meshing 3D triangular channal | rosol | FLUENT | 1 | September 7, 2007 16:52 |
tetrahedral meshing in square channel | Aashutosh Magdum | FLUENT | 4 | May 28, 2005 20:27 |
