meshing triangular channel
Dear friends
I have a problem with meshing the triangular channel since I try all types of mesh but the mesh did not generated to the triangle channel. Please who can to help me to meshing my channel with thanks |
Re: meshing triangular channel
Use the Triprimitive option. To apply this mesh topology you must change all nodes in face to the End type
Thank you
But how to change the nods to end type and this type of mesh Triprimetive to the faces or volumes |
In the face mesh icons there is icon (in top and 4th from left). then select the face and select the node. then click on End and then press apply. It should work.
After changing to all nodes in triangle to End , the default scheme for meshing will be the triprimitive. |
