February 20, 2008, 03:01 |
Plotting Contours of Experimental Data
Hi, I have an experimental data which I want to compare with my fluent results.. i'm interested in plotting contours of velocity (experimental data)on a plane How can i do that??
Regards |
February 20, 2008, 07:07 |
Re: Plotting Contours of Experimental Data
Hi u can try in softwares like Origin or Axum or Winsurf.. even Matlab can also do this for u
February 20, 2008, 09:53 |
If you want to do this in Fluent you can structure your data like an 'interpolation' file and read it in Fluent.
February 20, 2008, 14:27 |
you mean like a .dat file that fluent stores
February 20, 2008, 16:27 |
go to file interpolate menu and write out a sample inlerpolate file. use the same format for your experiment data. read the data back as an interpolate file. you don't have to match the exact locations, fluent will interpolate between the data points.
[General] paraview - plotting difference to reference data | joewe | ParaView | 0 | August 30, 2010 18:01 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Looking for the experimental data | COLOPOLO | Main CFD Forum | 2 | January 28, 2004 23:38 |
Simulated data vs. experimental data | moiami | FLUENT | 0 | December 19, 2002 01:03 |
Experimental data for fence at low Reynolds number | Kim Bindesboll Andersen | Main CFD Forum | 1 | September 26, 2002 13:54 |
