February 20, 2008, 16:44 |
Higher order polynomial problem...
Hello friends, yesterday i faced one problem and i m still searching answer for that, but couldnot. In my simulation i was having material properties at different temperatures. So i thought to define viscosity as a function of temp with help of Polynomial equation which is avalibale in fluent. i used higer order of polynomial(6 order). i found that solution was showing diverging behaviour. After that i took polynomial of lesser order(second order) in that case solutions was moving towards convergence. so why higher order is giving diverging solution?
1st order vs 2nd order | ken | FLUENT | 8 | March 14, 2013 03:43 |
modify fvMatrix / coupled equations / higher order diffusion | Jinming | OpenFOAM Programming & Development | 0 | May 7, 2011 06:20 |
Unstable flow simpleFoam 2nd order | Valle | OpenFOAM | 0 | August 26, 2009 08:12 |
Higher order Gradient Calculation | CFDtoy | Main CFD Forum | 3 | February 13, 2009 04:42 |
Higher order for phase volume fractions? | George Bergantz | CFX | 2 | December 11, 2000 11:55 |
