May 22, 2013, 04:49 |
CFD Analysis of mixing chamber in AHU
gökhan
Hi everybody,
I'm new in CFD. I have questions about boundary condition in fluent. I want to make a cfd analysis to see velocity motion in mixing cell in air handling unit. There are two inlet and two outlet boundary condition. Also there is a mixing damper in the middle. I enter mass flow inlet boundary condition for 1 and two number boundaries and others (3 and 4) are pressure outlet but i couldn't reach good solution . The air which entering from mass flow inlet 1 does'nt mixing with below air .Could you give me a suggestion |
May 22, 2013, 10:10 |
OJ
Rep Power: 20 |
From what I understand, the air entering from inlets has a least path of resistance through pressure outlets. So it will try to move out of the domain from there, instead of entering through the passage joining the two chambers, because there, the pressure will be obviously more than zero.
OJ |
May 22, 2013, 16:51 |
#3 | |
gökhan
My target is mixing %80 of first mass flow and %100 second mass flow . %20 of first mass flow must extract from pressure outlet one ( 3) NOTE: Number in bracket represent the numbers in jpg pictures. |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
CFD software capable of modal analysis? | Jim-gineer | Main CFD Forum | 4 | January 14, 2010 09:29 |
FDM vs FVM vs FEM in CFD analysis | ck5285 | FLOW-3D | 1 | September 1, 2009 10:51 |
CFD Analysis of pump | remith | CFX | 7 | October 6, 2008 07:57 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
