February 26, 2008, 04:08 |
Gambit error on opensuse
I installed GAMBIT without problems on openSUSE 10.3. However, when I start it it gives me the following error.
Starting /Fluent.Inc/gambit2.4.6/lnx86/gambit ... Gambit build SP2007051420. libxcb: WARNING! Program tries to unlock a connection without having acquired a lock first, which indicates a programming error. There will be no further warnings about this issue. libxcb: WARNING! Program tries to lock an already locked connection, which indicates a programming error. There will be no further warnings about this issue. gambit: xcb_lock.c:77: _XGetXCBBuffer: Assertion `((int) ((xcb_req) - (dpy->request)) >= 0)' failed. Received exception: SIGABRT (abort signal) Please send the GAMBIT.6617/jou and GAMBIT.6617/trn files to your local Fluent office or distributor. Also send a message including any relevant errors or warnings you see above in this window. You may wish to delete the temporary directory GAMBIT.6617 after sending the above files. ERROR: Please retain a copy of the GAMBIT.6617/jou, GAMBIT.6617/trn, and GAMBIT.6617/*.dbs files, any imported geometry and any relevant errors or warnings you see above in this window and contact support at your local Fluent office or distributor. Aborted I tried to run the workaround: export LIBXCB_ALLOW_SLOPPY_LOCK=1 but nothing changes Thanks |
Gambit on Opensuse install error | Thiago | FLUENT | 7 | December 14, 2013 07:59 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit - Odd Display -with out text - in Linux (OpenSuse 11.2) | pradeepmohanm | ANSYS Meshing & Geometry | 1 | December 20, 2009 11:17 |
Fluent / gambit on openSUSE 11.1 | Ralf Schmidt | FLUENT | 0 | February 24, 2009 04:37 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
