-   FLUENT (
-   -   fluent stops batch mode on error (
Ralf Schmidt February 26, 2008 12:46
I am simulation an fluent file created with 6.3 on Fluent 6.2.16. (there is only the older version available)
Now, there is always following error:
Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 1) (profile "" ""))
normally, that is no problem - the simulation is running fine and there are no further problems.
BUT: now, i want to run fluent in batch mode (reading , iterating and writing multiple files). And after reading the cas file in batch mode (the error appears) and then reading the dat file ("done"), fluent says, that an error stops the journal file.
What is the problem?? The Batch execution options checkbox "exit on error" is not checked.
Any idea??
Carlos March 1, 2008 11:35
Re: fluent stops batch mode on error
Are you sure you are reading a data file which matches the grid in the case file? Also, what other commands do you have after reading the data file? I assume you have things like initialize and iterate.
