Home > Forums > FLUENT
low-Re k-epsilon
Old   March 4, 2008, 16:27
Default low-Re k-epsilon
Manu
Hello, I'm using k-omega (lowâ€"re) model of turbulence on a Naca 0012 airfoil flying at a speed of 10 m/s, however I cannot get a fineness ratio smaller than 2 ! The lift coefficient is realistic, but the drag is 100 times much greater than it should be. Moreover when I plot the contours of omega it appears that the dissipation of turbulence only occurs within the boundary layer. Does anybody know how to solve this problem? Thanks, manu
Old   March 4, 2008, 23:45
Default Re: low-Re k-epsilon
NRD
RANS models in FLUENT are valid for flows which are fully turbulent. Its not clear when you say "low-re". Also if you are using standard wall functions, the value of y+ should be between 30 and 300. In my experience, results are sensitive to the value of y+, you can also try reducing the convergence criteria. Just wanted to share my views.
Old   March 5, 2008, 10:39
Dimitri
Manu, this is an assignment we've given you; the use of Forums is strictly forbidden... Just joking, try to work it out using what NRD has said which is enough to find the solution to yr problem.
Old   March 5, 2008, 10:49
Manu
Salut! En fait ça y est ça marche j'obtiens des coeff. de portance et trainee corrects. A plus!
Old   March 5, 2008, 10:52
Dimitri
excellent, alors c'etait le wall-function le probleme ou bien les valeurs de reference?
Old   March 5, 2008, 10:58
Manu
un mix des deux en fait, ma vitesse de référence était fausse donc j'obtenai des mauvais coeff, et a cause du wall function le rapport Cl/Cd était faux. c cool en tt cas, merci et � plus!
Old   March 10, 2008, 17:45
Andrès
Hi8 guys, I got the same problem; i can't get any closer but 127% (Cd); I've tried with several options, viscuos models etc, as u wrote in frech, i did't understand the full answer... can u translate plz.
Old   March 11, 2008, 03:47
Manu
Ok no worries, sorry about that. Actually I'm student, and it was an assignment on NACA 0012 airfoil with flow velocity quite low (10m/s) and each student had a different Rans model of turbulence to test on it. I had to test the low-re number version (i.e. solved up to the wall) of the standard k-omega model. At the early begining I made stupid coarse mistakes, as for instance I forgot to set the velocity of the flow in the reference value, so obviously the dimensionnless coefficients were wrong. I had some problems as well with the Cd, not because of Y+ (it was almost equal or below 1 everywhere), but because of the free stream value of the dissipation of turbulence, which were wrong (you should take care in setting realistic values for this parameters) I hope it will help you, Manu
Old   March 11, 2008, 10:16
Andrès
well, what I'm doing is also an assigment but it is at Re= 6xe06, it has been difficult to obtain the Cd (still working with a 126 % of error), the reference values are ok, the Y+ the same. can u tell me which are those free stream values you talked about?
Old   March 11, 2008, 14:44
Andrès
jeje , now I get what u mean, I'm using intensity (2,66 %)and hydraulic diameter (0.0248); and eventhought the results aren't as expected. any other tip? are those values right?
Thread Tools
Trackbacks are On
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 13 November 4, 2013 15:13
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 10:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
