March 5, 2008, 20:00 |
Urgent help on backflow turbulence
Hi Friends,
I'm using the k-w turbulence model when simulating my centrifugal compressor. i'm also using "K and Omega" as my turbulence specification method, however i'm unsure of the value to input into Turb. KE and Spec. Dissipation rate at my pressure inlet and also the Backflow Turb. KE and Backflow Spec. Dissipation rate at my pressure outlet. If i want to assign the outlet with turbulent viscosity ratio of 100 times than that of the inlet (laminar), what i suppose to do? Thanks a million for ur help! Remy |
March 5, 2008, 22:47 |
Re: Urgent help on backflow turbulence
sir,
where Can I get tutorials of 2.0 gambit please help me. Thankyou. |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
urgent : turbulence | abhay | FLUENT | 0 | October 15, 2008 02:23 |
Backflow Turbulence Intensity & viscosity ratio? | Remy | FLUENT | 0 | March 7, 2008 04:50 |
