-   -   Combustion Instability in Gas Turbine Combustors (http://www.cfd-online.com/Forums/fluent/47530-combustion-instability-gas-turbine-combustors.html)
yoyo March 6, 2008 11:50
Hi, Mates,
In terms of combustion instability resulting from the coupling of heat release with pressure oscillation, how to define the inlet and outlet boundary conditions? To my knowledge, the compressible effect should be taken into consideration, is it?
Any one could show me some experimental data regarding, in particular, the case of liquid fuel?
thx.
NRD March 6, 2008 21:51
Re: Combustion Instability in Gas Turbine Combusto
You are right. Compressibility effects need to be taken into account to study combustion instability. You can find vast literature on the topic of combustion instability in AIAA papers, Journal of propulsion and power etc. The "Theoretical and Numerical Combustion" by Poinsot and Veynante has an excellent chapter on Combustion instability.
yoyo March 7, 2008 04:19
Thanks a lot, NRD. But, LES is adopted by nearly all the cases with respect to C.I. discussed in that book mentioned by you. As far as URANS is concerned, defining suitable boundary condtions is a headache for me, considering both the compressibility effects and wave motion at the inlet and outlet.
Any suggestion about that?
SA March 9, 2008 09:43
yes read more and more hehheheh
Djamel March 16, 2008 07:39
Re: Combustion
How i can do the simulation withote combustion of non premexide combustion with FLUENT for confirm that the melonge is rechese
comment je peut faire la simulation de sans melange sans combustion dans FLUENT
