March 6, 2008, 08:21 |
grid adaptation
Hi, I use K-E turbulent model with standard wall fonctions and I need to adapt my grid by using Y+ or Y* , my problem is that the cells in some regions are so small and they are marked for croasening but they don't change after y+ adaptation use, can you help me? thanks.
March 6, 2008, 08:55 |
Re: grid adaptation
hi, it is not my cup of tea, however, Fluent may marked the original grid for coarsening and I know that the original mesh cannot be coarsed.
March 6, 2008, 09:33 |
Re: grid adaptation
Thank you for your answer, but it's really illogical to have the option of coarsening and can not use it, so I will use a large cell mesh and refine it, I hope the Y+ adaptation will work in this case.
March 6, 2008, 09:53 |
Re: grid adaptation
so, I was right? You have tried to coarse the parent mesh? If yes, then your problem should dissappear with using coarser mesh as parent one.
No grid adaptation | Pimmie80 | FLUENT | 1 | September 21, 2010 08:35 |
grid partition AND dynamic mesh adaptation !!!!!!! | bohis | FLUENT | 0 | January 16, 2009 03:00 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
floating point error during grid adaptation | Nurul Murad | FLUENT | 2 | September 5, 2001 19:15 |
