March 17, 2008, 06:31 |
udf problem of premixed combustion
I try to use udf to define the resource term of premixed combustion, and I just follow the example of the tutorials, however when I interpreted the .c file, I got the problem as follow;
line21: function "Compute_Trb_Vscal" not found(pc=6). line21: function "Calculate_unburnt_rho_and Xl" not found(pc=86) the code is like this: #include "udf.h" #include "sg_pdf.h" /* not included in udf.h so must include here */ DEFINE_TURB_PREMIX_SOURCE(turb_flame_src, c, t, turb_flame_speed, source) { real up = TRB_VEL_SCAL(c,t); real ut, ul, grad_c, rho_u, Xl, DV[ND_ND]; ul = C_LAM_FLAME_SPEED(c,t); Calculate_unburnt_rho_and_Xl(t,&rho_u,&Xl); if( NNULLP(THREAD_STORAGE(t,SV_PREMIXC_G)) ) { NV_V (DV, =, C_STORAGE_R_NV(c,t,SV_PREMIXC_G)); grad_c = sqrt(NV_DOT(DV, DV)); } ut = ul*sqrt( 1. + SQR(up/ul) ); *turb_flame_speed = ut; *source = rho_u*ut*grad_c; } |
combustion model in premixed combustion chamber | wuyu | FLUENT | 9 | February 16, 2018 10:40 |
temperature problem with non-premixed combustion | vic yang | FLUENT | 3 | June 5, 2008 00:50 |
Sawdust Combustion-Non-premixed Combustion Model | Jessy | FLUENT | 1 | June 19, 2007 10:59 |
A problem about partly premixed combustion | Z.P.YAO | FLUENT | 3 | January 8, 2006 06:19 |
Non premixed model - combustion validation problem | David | FLUENT | 2 | October 24, 2003 10:06 |
