Free Surface Effect on the AUV
Old   March 16, 2008, 00:44
Default Free Surface Effect on the AUV
Mahbub
Dear All,
I am simulating the water flow over under-water body and calculate the drag force acting on it. I want to set the upper surface as free surface and investigate the effect of wave at the free surface on the immersed body. Have you any experience in this field? With Best Regards.
Mahbub
Old   March 26, 2008, 05:11
Default Re: Free Surface Effect on the AUV
dongtao
can you give me this file"http://www.dt.navy.mil/hyd/tec-rep/vis-dra-cal/documents/viscous.pdf",thanks!my emial is: dongtaomail@gmail.com. are you studied on the podded propulsor?
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
VOF and strong surface tension effect phsieh2005 Main CFD Forum 1 August 30, 2005 06:56
Multicomponent fluids with strong surface tension effect Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 1 January 11, 2005 07:35
free RANS code with free surface ability Lou jing Main CFD Forum 1 July 11, 2003 14:43
[surface tension effect at free-surface ?] name Main CFD Forum 1 September 21, 2001 09:54
