March 13, 2008, 15:55 |
Symmetric condition
Quick question,
I splitted a cylinder into a 90 degree model and I run a 3D simulation. So the splitted faces has symmetric bc. So, when fluent gives me the volume flow rate it is for the whole model or just for the 90 degree mod? thanks |
March 15, 2008, 06:33 |
Re: Symmetric condition
Surely you can do some hand calcs to check this? I haven't looked at you problem obviously, but I think you should be using periodic boundary conditions, not symmetry. Symmetry would work for a 180 degree model. Regards, Scott |
March 16, 2008, 17:24 |
The flow rate is just for the sector alone and not the full thing. Unless you can guarantee no swirl down the pipe, use periodic zones instead of symmetry.
symmetric boundary condition relation with force | endee | FLUENT | 2 | December 16, 2007 04:54 |
Flow about symmetric shape is not symmetric | PetrK | CFX | 7 | August 23, 2006 11:54 |
symmetric URGENT please | paul | FLUENT | 1 | January 20, 2006 05:39 |
Symmetric BCs | mao | Main CFD Forum | 5 | May 19, 2005 09:11 |
UDF for 2d axi-symmetric case | Manoj | FLUENT | 0 | October 11, 2004 12:00 |
