Time Accuracy of the NITA - FRACTIONAL STEP method
Old   March 19, 2008, 05:37
Default Time Accuracy of the NITA - FRACTIONAL STEP method
Paolo Lampitella
i'm trying to perform some accuracy tests of the NITA - FRACTIONAL STEP time integration scheme employed in Fluent using the Taylor Test Case, which is a double periodic array of vortex whose kinetic energy is decaying in time.
I performed several simulations with several grids, domains, boundary conditions, pressure interpolation schemes and space discretizations but i have misleading results.
Using exactly the same conditions cited in the paper
Sung-Eun Kim Boris Makarov
An Implicit Fractional-Step Method for Efficient Transient Simulation of Incompressible Flows
AIAA 2005-5253
Old   March 19, 2008, 05:45
Default Re: Time Accuracy of the NITA - FRACTIONAL STEP me
Paolo Lampitella
Sorry, i pushed the wrong button.
Using the same conditions cited in the paper, i obtain the same results cited there, a 2nd order accurate in time scheme.
But, just going outside the conditions cited there, i always obtain only a first order time accurate scheme.
So i'd like to know if someone has experience in this or even know if there are some other papers where the scheme has been more rigorously tested and with which compare my results.
Thanks a lot, any help is appreciated
Comparing between the Fractional step method and the SIMPLE method ghlee Main CFD Forum 1 April 10, 2012 16:59
Time accuracy of NITA - FRACTIONAL STEP in Fluent Paolo Lampitella Main CFD Forum 0 March 19, 2008 07:20
Question about fractional step method Harish Main CFD Forum 2 September 25, 2006 09:29
fractional step method Fuka Main CFD Forum 1 March 23, 2006 17:01
Fractional Step Method interpretation Jean-François Corbett Main CFD Forum 2 March 1, 2006 10:38
