Smooth Grid Error! Help
Old   March 23, 2008, 09:04
Default Smooth Grid Error! Help
seasoul
Everybody! I am a newbie in Gambit and Fluent.
When I used smooth mesh option in Gamibt to improve my meshing, I got a negative volume, so I import the unsmoothen mesh into Fluent and use smooth/swap Grid option. After several smooth-swap steps, the supposed ever-decreasing "number faces swaped" begin to increase; at the same time, "Warning, non-positive volumes exist" comes out. Is "smooth" step always necessary? If so, is it necessary to get the "number faces swaped" decreased until it reaches zero?
Here is the error message, some are : ----------------------------------------------------------------------------------------------------------
Welcome to Fluent 6.3.26
Copyright 2006 Fluent Inc.
All Rights Reserved
Loading "D:\appl_sw\Fluent.Inc\fluent6.3.26\lib\fl_s1119.d mp" Done.
4 smoothing iterations complete
Number faces swapped: 619 Number faces visited: 5511
Number faces swapped: 358 Number faces visited: 4020
Number faces swapped: 179 Number faces visited: 3210
Number faces swapped: 89 Number faces visited: 2823
Number faces swapped: 52 Number faces visited: 2617
Number faces swapped: 34 Number faces visited: 2489
Number faces swapped: 21 Number faces visited: 2412
Number faces swapped: 12 Number faces visited: 2358
Number faces swapped: 15 Number faces visited: 2310
WARNING: non-positive volumes exist.
Number faces swapped: 9 Number faces visited: 2277
Interrupting... Done.
> Interrupting... Done. ------------------------------------------------------------------------------------------------------------
Old   March 24, 2008, 10:56
Default Re: Smooth Grid Error! Help
devesh
Hi dear.......
as per my knowledge, If your geometry is very complex then you can use smooth the grid because during the meshing, by default it does smoothing of grid. After that If you want to go for smoothing option, then you go for "redomain" option in grid then u can smooth the grid or you can go for GRID adaptation option.
If I am wrong for your desired solution, then I am sorry. But above option may be helpful for you
Regards Devesh
smooth DTF surface N.R. CFX 0 July 25, 2007 13:45
ICEM 10 smooth transition error Stephen CFX 3 March 13, 2007 09:23
smooth adaptive grid refinement Wouter Harteveld FLUENT 0 November 10, 2005 11:21
Smooth Grid Gernot FLUENT 0 August 19, 2005 16:00
smooth the joint? zhang junmei FLUENT 0 September 12, 2001 10:23
