March 23, 2008, 22:25 |
FFT in FLUENT
Dear All In the first sorry for my bad English. I have a problem about FFT in Fluent. I create a "point" in my fluid domain and need to collected the data for FFT ( Running by LES and use surface monitors , report type : mass flow rate , report of : Pressure , Static pressure )after I open the files all of my data show "0" all points. Can every body help me for this case.
March 24, 2008, 00:37 |
Re: FFT in FLUENT
You need to change the scale I think. If you are after the peak freq., change the scale of x-axis from 0 to 1.
Could you also tell me do you get a good results with LES? What approach do you take for LES modelling? Sham. |
March 24, 2008, 03:50 |
Re: FFT in FLUENT
Thank your for your help , do you mean the scale in surface monitor plot or where ???.
March 24, 2008, 04:13 |
Re: FFT in FLUENT
scale in FFT graph
March 24, 2008, 04:18 |
Re: FFT in FLUENT
I found this error
Warning :Read_Signal: FFT can handle a costant sampling interval only! Jump in sampling interval at number 30 is more than 1 percen ! what does it mean ??? |
March 27, 2008, 07:08 |
Re: FFT in FLUENT
it means that your interval is very small. try increasing it, then u probably get your plot right.
March 31, 2008, 09:38 |
Re: FFT in FLUENT
You mean Data sampling for time statistics ( sampling interval)or where ??
March 31, 2008, 11:08 |
Re: FFT in FLUENT
i mean when u go to axes, then u can select the interval of plotting. i had the same problem, and when i increased this interval of ploting(the range), it worked.
August 14, 2009, 15:02 |
FFT warning
#9 |
While taking FFT of a signal in Fluent I get the following warning
Warning: Unknown x-function in Process_and_Plot_Signal function. Can anybody tell me what does it mean? |
August 15, 2009, 07:16 |
#10 |
abdul samad
Rep Power: 16 |
doesn't matter....ths s no error
August 15, 2009, 07:18 |
#11 |
abdul samad
Rep Power: 16 |
u r doing fft for sound amplitude or wt?
August 15, 2009, 08:04 |
#12 |
no just simple FFT with ideal gas and transonic flow and density based solver.
the problem is that I am getting very low value of Power Spectral Density on y axis (e-09) is it ok? |
August 15, 2009, 08:21 |
#13 |
abdul samad
Rep Power: 16 |
these values are pretty lesser........
perhaps if u can expalin ur case in detail...........i may help |
August 15, 2009, 09:21 |
#14 |
I am simulating unsteady flow over Ariane 5 rocket. The solver is density based explicit and time formulation is explicit as well. I think in this case the number of samples=no of iterations. I want to simulate till 1 m sec. When I get the FFT in between about 2e-04 second this situation arose which I just discussed. I am using URANS (with k omega model). for SA model I dont remember bt y axis but it gave me another warning that differnce in sample 1000 (I hope its 1000 iter because I increased CFL no there) is less than 1 %.
Hope its clear now |
November 2, 2009, 00:54 |
#15 | |
Morteza
Rep Power: 16 |
i guess u should use first K-epsilon model until ur residuals converges ,after that by inputting the:"solve/initialize/init-flow-statistics" in the text command.then u can choose the LES model. good luck |
May 10, 2014, 07:32 |
#16 |
Charles Odijie
I am new here, I registered few mins ago. I need help with reading FFT files. Non of the files that were saved during d calculation will loading into d fft. I'm trying to Plot d graphs on 'power spectral density, frequency and strouhal number. After d simulation, I clicked Plots/FFT/Set-up/Load Input files.... no file appeared. I scrolled down to All Files, and some file showed up, saved in .dat and .cas. When I tried to load one of d files, this error appeared: 'error reading file.
What should I do?? I need help please. |
October 24, 2014, 10:46 |
#17 |
kabilan.B
Rep Power: 15 |
how to define les model in fluent 6.3.
thank you |
October 24, 2014, 14:07 |
#18 |
for les model you need to check on unsteady and the model should be 3D.
October 25, 2014, 09:03 |
#19 |
kabilan.B
Rep Power: 15 |
thank you sir..
March 26, 2018, 13:00 |
non dimensional time step
#20 |
erfan
Rep Power: 8 |
hi i have problem to find non dimensional time step
this formul is ut/D and D=0.04 , U According to Re=100 dansity=1000 and viscosity=0.001002 it will be obtained U=0.0025m/s non dimensional time will bw obtained 77 how can do it? |
Fluent in Linux vs. Fluent in Windows | Melih | FLUENT | 6 | November 16, 2014 09:39 |
Fluent/Unix vs. Fluent/Windows | sjjaber | FLUENT | 10 | January 5, 2005 16:58 |
Running FLUENT 6.0 sims. on FLUENT 6.1 | ozgur | FLUENT | 2 | April 2, 2004 13:23 |
