April 2, 2008, 02:31 |
Small hlpe reg rsm model.
Dear friends:
I am running a wire wrapped rod bundle case and i am trying to use the RSM turbulence model as per literature suggestion.This turbulence model alone is diverging after some iterations reaming two equation turbulence models are converging very nicely. Can u suggest something for to solve this problem. Thanks in advance, Sreenivasulu Reddy.T |
April 2, 2008, 23:53 |
Re: Small hlpe reg rsm model.
try converging the simulation with the two equation model and then switch on the RSM model. Use the two equation solution as a starting point for RSM.
April 3, 2008, 00:46 |
Thank you Aidan. I tried that way only, still not converging actually it is diverging also.
April 3, 2008, 00:48 |
have you tried using unsteady solver?
Model of a small displacements piston | Smagmon | CFX | 6 | March 3, 2009 13:06 |
How to model many small holes in a large domain? | Bryan Woods | FLUENT | 3 | February 5, 2009 19:34 |
Large Scale Model:Small scale computer | gull | COMSOL | 0 | March 5, 2007 06:37 |
turbulence model for oil flow thr' small gap | carno | Siemens | 2 | August 31, 2005 08:12 |
How Small is Zero ! | Ajay Rao | FLUENT | 2 | December 5, 2003 03:26 |
