Home > Forums > FLUENT
rotationally periodic properties vs temperature
Old   April 7, 2008, 13:13
Default rotationally periodic properties vs temperature
Sasha
Hi. I'm trying to model fluid flow between two rotating cylinders held at different temperatures with fluid viscosity depending on temperature. In translationally periodic flow its impossible due to the flow development. Is it so in rotationally periodic flows in fluent, e.g. if I'll model only a slice and not the whole 360degs. Thanks a lot.
Thread Tools
Trackbacks are On
Properties of air versus temperature AND pressure Vincent Main CFD Forum 5 July 28, 2008 06:28
temperature BC for periodic BC qunwuhe@hotmail.com Main CFD Forum 0 June 24, 2007 01:00
FIDAP and temperature dependent mat properties semetay FLUENT 0 July 11, 2006 13:45
Problem with transport properties depending on Temperature galaad OpenFOAM Running, Solving & CFD 5 December 6, 2005 13:51
Rotationally Invariant Methods Praveen C Main CFD Forum 0 May 14, 2001 13:11
