Home > Forums > FLUENT
error mesage
Old   April 9, 2008, 03:09
Default error mesage
Jorge
Hi. I am trying simulate a proces include energy and radiation, for ventilation in greenhouse, using turbulence model ske and 2D, but at moment to starting the proces, show a error message "divergence detected in AMG solver: temperature"
What's up?
Old   April 9, 2008, 13:57
Default Re: error mesage
Paul
Try going to solve > solutions and deselecting temperature and then try running it to see if it will work.
If it works for a while, you can try reenabling temperature and see if it crashes or not.
Old   April 10, 2008, 02:57
Jorge
many thank's, I going to try, another time
Old   April 10, 2008, 03:59
Jorge
Hello Paul. the problem persist. when the proces is only for fluxes, no problem for converge, but if activate energy, and consequently, boussinesq and gravity, I have a problem for "turbulent viscocity limite to viscocity ratio is >" however converge. Them, if activate radiation model, message "Error: divergence detected in AMG solver: temperature. Error Object: ()" is my great problem.
Thank's a lot
Old   April 14, 2008, 04:52
Rami
This is a manifestation of inability to solve the discrete algebraic equations. There are many controls that affect this. The most evident is the relaxation factors. Others can be the discretization scheme and many others, like gradient discretization, coupling etc. Another issue may be the well-posedness of the problem, which should be the first thing to re-check.
Old   April 14, 2008, 06:09
Jorge
I belive you have reason, becouse, if I change the turbulence model, from standar to RNG, the proces is other, either, when the values of the factor relaxetion are modified
how long is the effect of the density, in relation with the temperature, when the gravity is enable, in convection natural conditions?
many thanks and, I will cotinue
Thread Tools
Trackbacks are On
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 11:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Error Mesage from UDF Quak FLUENT 0 July 12, 2005 16:43
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 18:11
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
