DEFINE_ADJUST & Domain...
Old   April 4, 2008, 10:02
Default DEFINE_ADJUST & Domain...
Corentin
Hi!
I am doing an instationnary simulation and I have several iterations per time step.
There are some variables that I would like to reset at each time step but also at each iteration.
I am of course working with a UDF.
To reset after a time step, I am using the DEFINE_EXECUTE_AT_END fuction, and it's working well.
But I do not succeed to reset my variables at each iteration.
To do so, I am trying to use the DEFINE_ADJUST function, but it need some domain, and I don't know what to do.
First : why does it need a domain? The function that reset after each time step doesn't need one...
Anyway, I don't know which domain I should put in.
I am working on someone else code, how could I get the domain, I don't see it?
All I know is that the variables that I want to reset are in a Define_Source which is working on a (c,thread).
I thought my domain would be 'thread', but...
When I put 'thread' or 'domain', I have no errors, but it's not working.
Thank you!
Old   April 4, 2008, 10:36
Default Re: DEFINE_ADJUST & Domain...
RE13
The domain pointer is automatically passed to the DEFINE_ADJUST macro from the solver
Old   April 7, 2008, 03:35
Corentin
You mean that it should be done automatically?
What should I type, then?
DEFINE_ADJUST(name,domain) ?
I tried, it didn't work...
Old   April 7, 2008, 09:57
RE13
paste your DEFINE_ADJUST code here so we can see if there are any mistakes
Old   April 8, 2008, 02:57
Corentin
Ok, thanks.
I just type this:
DEFINE_ADJUST(name,domain) { x=0; }
There is no error at compilation, but the variable x is not reset to zero.
What's wrong?
Old   April 8, 2008, 17:50
RE13
how are you checking the value of x? The define source macro is also called every iteration (but after define adjust), if the value of the variable isn't checked before it is reset than that could be the cause
Old   April 9, 2008, 02:28
Corentin
I am sure the DEFINE_ADJUST isn't done because I put some printf command in it, but this printing is never done.
Old   April 9, 2008, 02:58
max
Are you sure that you have hooked your Adjust-Function:
Define/User-Defined/Function-Hooks?
Max
Old   April 9, 2008, 10:37
RE13
I was thinking the same thing...
Old   April 9, 2008, 11:30
Corentin
Yes, I hooked it. I had forgotten, but now it is done, and still not working
DEFINE_ADJUST Problem Davis Yohanes Arifin FLUENT 14 February 29, 2020 04:37
C_UDSI_G() use in DEFINE_ADJUST Gemini FLUENT 1 July 5, 2013 00:12
Could I use DEFINE_ADJUST to set B.C ? pour FLUENT 0 May 22, 2008 13:07
About DEFINE_ADJUST sagga FLUENT 1 February 3, 2006 09:49
DEFINE_ADJUST Tomm FLUENT 0 December 7, 2005 10:53
