Import geometry in GAMBIT
Old   April 10, 2008, 06:25
Default Import geometry in GAMBIT
Cristiano
I'm dealing with CAD geometry realized by Solidworks Is it importable in GAMBIT? Which is the right extension file?
Thanks
Old   April 10, 2008, 06:56
Default Re: Import geometry in GAMBIT
mAx
you can try with STEP file (I currently use this way)
Old   April 10, 2008, 12:42
Renato Pacheco
you can try sat file. i actually dont know if solid wokrs can export this kind of geometry, but fluent can read it.
Old   April 11, 2008, 03:26
red lemon
Read in the parasolid file directly (*.x_t) and use the direct read option (File>Import>CAD>Parasolid direct read) or use translation to convert from parasolid format to native GAMBIT ACIS format (File>Import>Parasolid). The former is less likely to corrupt data but will come in as virtual hence reduces geometry operations (entities will be c_*), though you might be able to convert. Also you can use the Gambit SOlidWorks CAD connection tool at v1.2.4 (for 2006/7/8) which is free and can be obtained from www.fluentusers.com which will help with transfer.
Old   April 21, 2008, 05:42
rupal
you can save as the solidworks file as .igs, .step, .parasoid and then import it into gambit.
Thanks rupal
Import 2D Geometry to Gambit Nathan ANSYS Meshing & Geometry 3 March 27, 2017 10:26
import geometry in GAMBIT cristiano FLUENT 27 November 6, 2014 17:43
GAMBIT, CAD import, clean up geometry problem Nuray Kayakol FLUENT 1 December 30, 2007 11:43
iges geometry file gambit import giacomo FLUENT 0 May 14, 2007 12:32
Multiple import of Geometry in GAMBIT(Catcon Simu) Amod kumar FLUENT 0 July 21, 2006 23:55
