Algebraic Stress Model(ASM) in Commercial Softwares
Like Tree4Likes
  • 2 Post By sbaffini
  • 1 Post By sbaffini
Old   December 23, 2014, 10:37
Default Explicit Algebraic Reynolds Stress Model(EARSM) in Commercial Softwares
farhad
golriz is on a distinguished road
Hi everybody,
I have a question.
Is there any commercial CFD software that uses the EARSM model in turbulence modeling?
I search it in Fluent, but I did not find any option about this model in viscous modeling part.
Can anybody tell me some comments about it.
Regards,
golriz is offline   Reply With Quote
Old   January 11, 2015, 14:21
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
from the Fluent TUI type:
(allow-easm-model)
golriz and thedal like this.
sbaffini is offline   Reply With Quote
Old   January 11, 2015, 15:00
farhad
(allow-easm-model)
Thanks for your Reply.I Can not find it in the TUI type.
I am using the Ansys Fluent 14.5. you can see the attachment file.
There is not any ASM model there.
Old   January 11, 2015, 18:43
sbaffini's Avatar
Paolo Lampitella
If the command is given correctly, you shoul receive the following message:
The EASM model is now available in the interface.
Try, maybe, from the GUI (i also have them from the TUI), under the k-eps and k-w models (there should be the additional EASM option).
golriz likes this.
Old   January 14, 2015, 02:07
farhad
Thanks again.
I gave the command correctly, but there is not the EASM model in the list shown. Neither from the TUI nor from the GUI. Please see the attached file.
I can enable the other models from TUI, but when I give the ke-easm command, the "invalid command [ke-easm]" is shown.
Do you have any other suggestions?
Regards,
Old   January 15, 2015, 07:36
sbaffini's Avatar
Paolo Lampitella
Just to be sure, have you tiped in the console:
(allow-easm-model)
exactly in the way it is written above?
golriz likes this.
Old   January 15, 2015, 08:21
farhad
Thank you very much.
By the above way, the easm model was added to the viscous menu.
Is there any other model that can be enabled by this way?
such as non-linear k-e model?
Old   January 15, 2015, 14:33
sbaffini's Avatar
Paolo Lampitella
Two more options are:
1) (allow-v2f-model)
2) (allow-ke1e-model)
Notice that i was only aware of the v2f option until, by looking at (modify according to the installation path and Fluent version):
C:\Program Files\ANSYS Inc\v150\fluent\fluent15.0.0\src\turb.h
line 40 circa, i found the enumeration for more turbulence models than usually available. Maybe you can figure out how to enable some others
Old   January 15, 2015, 16:03
farhad
Thanks again.
With Warm Regards,
Farhad
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
implement explicit algebraic stress model EASM Thomas Baumann OpenFOAM 4 January 23, 2012 11:41
Two Phase flow modeling in commercial softwares Sandeep Rane Main CFD Forum 9 February 17, 2010 06:23
Algebraic Stress Model and Collocated grid Keur Main CFD Forum 0 May 31, 2005 21:46
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
