Home > Forums > FLUENT
refinement of cells only in ONE direction
Old   April 12, 2008, 15:43
Default refinement of cells only in ONE direction
Ralf Schmidt
Hi!
I have a mesh, that is made of cells that have a low hight (in x direction) and a large width (in y direction, for a 2d case).
Now, i want to locally refine the cells, but only reduce the with (in y direction), otherwise, to many cells would result.
is that possibly??
Ralf
Old   April 12, 2008, 20:36
Default Re: refinement of cells only in ONE direction
AAA
Hi
Go to Adapt-->iso-value-->Grid-->y surface area
Specify an Iso-max value lower than that of your elements.
let me know if this helps
Regards
AAA
Old   April 13, 2008, 12:53
me
The method above is only suitable where growth follows cartesian direction in all locations so is very limited and likley only applicable to more idealised geometries esp for adaption of prismatic layers.
Anisotropic adaption (refinement in one direction) will be available in Fluent12 as a stand alone GUI utility. You can test in the beta version for now only.
Thread Tools
Trackbacks are On
Refinement Sara CD-adapco 0 August 5, 2008 12:18
different of WS in X direction and WSX James CFX 0 May 2, 2008 18:03
Shell cells to Fluid cells Mahbub CD-adapco 1 October 20, 2003 15:21
Adaptive refinement for arbitrary cells jdc Main CFD Forum 0 August 7, 2003 12:41
UDF: neighbour cells, upwind cells Dmitriy Makarov FLUENT 0 February 18, 2001 14:53
