Home > Forums > FLUENT
System jams when re-opening
Old   April 12, 2008, 20:02
Default System jams when re-opening
AAA
Hi to All
Whenever I re-open an existing case/data file that was working OK before, and want to continue iterating, the software jams.
Has anyone encountered such a problem before?
Regards
AAA
Old   April 12, 2008, 22:12
Default Re: System jams when re-opening
AAA
Hi again
My problem (in more detail) is that the software becomes idle when I try to keep iterating through a case having a "sliding mesh" modeling.
Regards
AAA
Old   April 13, 2008, 12:56
me
For sliding grids the case is transient and so each mesh has a specific data field. Make sure they match. Is the case from a later Fluent version? Does the grid check succeed? Can it be initialised and run? Run a case chek if using F63.
Old   April 14, 2008, 04:57
AAA
Thanks for your reply
What I am really doing is that I am using the sliding mesh facility to analyze different configurations (rather than redrawing the whole thing in Gambit again for about 100 cases). Each time step provides a new domain setup, and I would like to switch the unsteady simulation to a steady one after getting the new domain and keep iterating by assigning the sliding mesh zone with a 0 m/s velocity. At every time step, the case/data files are Autosaved, and I can re open them with no problem. But for each of these case/data files I previously saved, I can not keep iterating again once I re-open them.
The case and data files match.
I am using Fluent 6.3
The grid check is OK.
But the case/data files CAN NOT be initialized and run again, here is the problem!
AAA
Thread Tools
Trackbacks are On
Gambit is not opening soniya FLUENT 2 August 21, 2008 07:25
Opening Andrew CFX 4 April 20, 2006 14:00
opening BC Ng Khai Ching CFX 1 October 8, 2004 15:34
Temperature at Opening cui CFX 1 December 18, 2003 12:52
JOB-OPENING Selina Tracy Main CFD Forum 0 February 22, 2003 00:55
