Multiple reference frame
I'm using multiple reference frame for centrifugal fan CFD analysis. Region around the blades are set to be rotating frame and the housing is static reference frame. Do I have to model the volume of the housing of the centrifugal fan and specify 0 RPM? What is the direction of the rotating frame?Following the blades rotation or opposite? Thanks |
Re: Multiple reference frame
you have to model the housing also. No need to give any rpm for that. Frame rotation direction is same as blade roation.
| All times are GMT -4. The time now is 10:14. |
