December 29, 2010, 12:33 |
help with setting up non-newtonian model
Sandeep
Rep Power: 15 |
Hello all,
I am trying to simulate a two phase vof model in which one of the phases is a polymer and the other is air. When i try to define viscosity of the polymer in the properties table with non-newtonian powerlaw model, at the end it says that "Note: Enabling energy equation as required by material density method. " and the solver is automatically enabling energy equation which I dont want to. I just want to simulate the fluid mechanics part of the case. Please help me what wud be the problem?? Thanks Sandeep |
December 29, 2010, 17:32 |
Real Name :)
Rep Power: 16 |
Sandeep,
Depending on the model you choose for non-Newtonian behavior, a reference temperature is required. If a reference temperature is required, the energy equation must be enabled. Please look at the Fluent manual (section 8.4.5) and you'll be able to see which non-Newtonian models require a reference temperature Regards, ComputerGuy |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
Surface roughness setting for a model in wind tunnel test section | Sharon | CFX | 12 | March 31, 2009 13:09 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
