April 7, 2008, 08:08 |
Fluent in text mode
Hi!
I'm running fluent 6.3.26 in unix (text mode -gu). It all works fine but i have the following problem. When i iterate (for example it 50) fluent calculates only one iteration! I switched off any residual/monitor plot. Any idea? Moreover i used text mode in order to decreade the RAM needed. Is there any possibility that with text mode the necessary RAM will be decreased? What about speeding up the calculations? Thanks in advance Aris |
April 15, 2008, 07:13 |
Re: Fluent in text mode
I found the problem. "It" iterates in the curent time step. The correct is dual-time-iteration! Still, does anybody knows if the necessary RAM will be decreased?
text shortcut commands for fluent | senthil | FLUENT | 0 | November 21, 2007 13:39 |
How to run the CFX-solver in text-mode? | bcomz | CFX | 2 | November 15, 2005 23:08 |
Changing colors in fluent text menu | venugopal | FLUENT | 0 | July 16, 2004 13:20 |
Fluent Command Text to display several Partic | Laurence Wallian | FLUENT | 2 | September 16, 2003 08:38 |
create executable and batch file in text mode | Johan | Siemens | 2 | July 23, 2000 12:02 |
